1 Radiator Feed Not Hot
Postby granthamdisco » Sun Dec 20, 2009 9:20 am
my bathroom radiator is stone cold & the feed pipe is also cold - Not hot coming through
All others good
I added some water last night as pressure was slightly low
Yesterday feed pipe was hot but radiator wasnt - I bled it & didnt fix it
I turned all others off & it worked problem out
granthamdisco
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby balhamjames » Thu Dec 31, 2009 9:35 am
I have a similar problem. All my radiators work brilliantly, except for one. I have bled it and that's not the answer. It is full of water, only the water is cold. The feed is hot, and the valve is open, but for some reason hot water doesn't seem to be going into the cold radiator. It was switched off for many years, and since I turned it back on has never got hot. Grateful for any suggestions.
balhamjames
Rank: Labourer
25%
Postby Steve the gas » Fri Jan 01, 2010 10:19 am
Do you have a TRV on that rad?
Steve the gas
Rank: Site Agent
56%
Postby rosebery » Fri Jan 01, 2010 11:40 am
Is the lock shield valve open?
rosebery
Rank: Project Manager
Postby balhamjames » Fri Jan 01, 2010 6:26 pm
the lockshield valve was indeed the problem - turned out it was turned off. So recommend looking at that for the other person who was having a similar problem - I just needed to unscrew the plastic cap and give the valve a couple of turns open with a wrench / pliers, and problem sorted! Many thanks to the person who suggested this.
balhamjames
Rank: Labourer
25%
Postby benn_plumbing » Fri Jan 01, 2010 8:54 pm
hi, sounds like the radiator valve is blocked not allowing a flow through that rad sometimes jus tunrning the valve off then on again works do both sides just incase.
benn_plumbing
Rank: Labourer
25%
Postby rosebery » Fri Jan 01, 2010 10:45 pm
"Many thanks to the person who suggested this."
Au plaisir.
rosebery
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
