The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
Red House TV - Looking for new DIY stories
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    230V or Volt Free Stat which one do I use?
    Post a reply
    3 posts • Page 1 of 1
    Postby cemhlm » Sat Dec 20, 2008 12:13 pm
    About 1 month ago I changed my old electr-mech Thermostat for a Digital Stat, it was easy to do, the new Stat a Sunvic 7501 required a 2 wire connection - Live and Call for heat, no neutral or earth was needed, 2 x AA batteries provoded the power to the Stat. Since installing the Sunvic it became obvious that the Stats position is just to near the kitchen door, when the door is opened the heat from the kitchen turns off the stat, keeping the kitchen door shut is not an option, moving the Sunvic is also not an option. The solution is a Wireless RF Stat, I can then place the Stat away from external heat sources.
    The RF Stat I have found which is easy to use is the Salus RT300RF Model, the Installation instructions can be found if you visit "salus-tech.com/manuals" and then search for the correct manual.
    I do not want a Programmable Stat, this model allows easy to use up - down and set options nothing else, anything that requires programming is a no no for my wife, she has a mental block on all things high-tech.
    If you look at the installation instructions there are 2 options for wiring this model, 230v and volt free, bearing in mind how the current Stat is wired ie Live and Call for heat, am I right in assuming that the 230v wiring is the correct option for me. wiring in the L and N seems straightforward, but the Call for Heat wire is not so obvious looking at the diagram the SL position is where this wire would go. as the diagram states that * is not normallu used, which one do I use?
    Any advice is apprecaited.
    cemhlm
    Top
    Sponsor
    Postby plumbbob » Sat Dec 20, 2008 2:18 pm
    This is a tad more difficult than it sounds.
    The main problem is the thermostat needs an extra wire that will not be available. Remember the live you already have is only live when the timeclock is calling for heat. The thermostat needs a permanent 24hr live for it to operate and remember it's settings.
    As there is a timeclock in the circuit (I am assuming this is so) you should use the volt free option otherwise the timeclock will be bypassed.
    The connections are
    L = 24hr permanent live
    N = Neutral
    Com = Existing live to old thermostat
    NO = Switched live to boiler (Call for heat)
    plumbbob
    Top
    Postby sparx » Sat Dec 20, 2008 9:41 pm
    see my answer on leckie post
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • Can I use my line voltage thermostat as volt-free?
      by alan hr » Tue Jan 01, 2013 6:59 pm
      Last post by stoneyboy View the latest post
      Wed Jan 02, 2013 10:50 pm
    • can volt free room stats work motorised valves?
      by gav78 » Fri Dec 10, 2010 9:10 pm
      Last post by sparx View the latest post
      Fri Dec 17, 2010 3:34 pm
    • Hot water stat overides heating stat
      by Clements » Wed Nov 12, 2008 8:56 am
      Last post by beckp View the latest post
      Thu Feb 05, 2009 10:50 am
    • Boiler trigger is 12V, but UFH outputs 230V
      by Haggles » Fri Jan 20, 2012 7:28 pm
      Last post by Dick Puller View the latest post
      Sun Jan 22, 2012 9:05 am
      by Haggles » Fri Jan 20, 2012 8:02 pm
      Sun Jan 22, 2012 9:20 am
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB ® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
