Hi, wondering if anyone can help me.
We have a semi-gravity heating system (ie the CH is pumped, but the DHW is just gravity fed) and i'm looking at upgrading so we have some control over the cylinder water temperature. Typically the water is far too hot and you have to add large amounts of cold, which seems a waste. I know I could upgrade to a fully pumped system, but i'll be too expensive to have the plumbing changed.
I done some research and found I can use a "C Plan". Basically add in a 28mm 2 port zone valve, Room and Cylinder thermostats and i should have more control than I have already. Currently I have TRV's, programmer and just the Boiler stat.
What I need to know is where can I put the motorised valve. I understand it goes on the return from the cylinder??? Can I place it near the boiler itself, or does it need to be near the tank? The tank is about 8meters from the boiler. Having it near the boiler means the wiring is so much easier then.
If anyone knows any issues/problems I may have with doing any of this please let me know. I don't want to start cutting the 28mm pipe and find it wont work after :(
Many Thanks
- HOME
- DIY PROJECTS
- DIY TIPS AND TRICKS
- REVIEWS
- GARDENING
- DIY VIDEOS
- GREEN LIVING
- HIPS
- FIND TRADESMEN
- PRICE DOCTOR
- FORUM
- BLOG
- NEWS LETTER SIGNUP
- SHOP
- SUPPLIERS
- ADVERTISE HERE
- PRESS
