Air Conditioning vent
Postby briana » Wed May 07, 2008 11:03 pm
I bought a portable air conditioner from B&Q. The instructions say the end of the flexible vent tube should be placed outside of an opening window. But all of my opening windows are too high for the tube to reach, and the unit is too heavy to place on a high pedestal. I am told that I cannot increase the length of the tube because this will cause too much resistance to the flow and cause the unit to fail. But I do have a fully functioning open fireplace and chimney. Can I mount the end of the air con vent tube to vent up the chimney?
briana
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby ALDA » Thu May 08, 2008 9:49 am
BRIANA,
YOU COULD INSTALL A CAT FLAP IN AN EXTERNAL DOOR AND UTILISE THIS TO VENT THROUGH.
IF YOU PURSUE YOUR IDEA OF UTILISING THE CHIMMNEY, HAVE IT CHECKED OUT FIRST AND SWEPT TO MAKE SURE IT IS CLEAR AND THERE'S NO CHANCE OF ANY OLD SOOT FALLING.
CHEERS,
ALDA.
ALDA
Rank: Foreman
65.7%
Postby htg engineer » Thu May 08, 2008 8:42 pm
If the chimney is used by a gas fire, then no you cannot use it for the air-conditioning vent.
For the unit to operate effectively the vent needs to be direct to outside - to get rid of the hot air - the vent can be through a wall, door or window.
No way of doing this ? return the unit as it's no good for your situation.
Htg
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
