Air going round and round
Postby btgriff » Wed Feb 27, 2008 8:04 pm
I've had a radiator off for decorating and now I'm stuck with a bit of air in my system that I can't seem to clear. It doesn't seem to want to collect in a radiator, whenever I bleed them I get water coming out. Yet I can hear the air gurgling round, normally at a couple of radiators.
The system is sealed with a ferroli modena combi boiler located in the upstairs airing cupboard. All the radiators have TRVs fitted except the bathroom one.
Any advice appreciated.
Ben
btgriff
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Thu Feb 28, 2008 9:33 pm
Is the auto-airvent on the boiler open ? have you vented the pump ? If yes and all the radiators heat, leave it and it will find it's way out eventually.
Are you sure it's air, could it not just be the radiator valves rattling abit ?
Rank: Project Manager
Postby btgriff » Fri Feb 29, 2008 3:31 pm
I'll have to check the vent on the boiler. I have found that after the heating has been on for a few hours that some air does collect in one radiator so I guess it will come out eventually.
Are the auto air vents reliable? I have read they can be a bit problematic.
btgriff
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
