Air in central heating system
Gateman
Post by Gateman » Thu Feb 05, 2009 6:40 pm
I have a conventional oil fired c/h system in a bungalow that I have rented out for over 2 yrs .
Previous tenants have not reported any problems but when checking system at change of tenants (after property empty 1 mnth) I descovered it was noisy (banging -particularly in cylinder) and rads full of air.
Bled rads but air still got into system- appeared to be through vent pipe and small amount of water also getting pumped back into header tank; reduced pump speed to 2 which helped (Setting 1 didn't pump water through boiler -hight of approx.2 meters above pump which is set almost at floor level) but rads still need bleeding approx daily and noisy particularly after hot water drawn off for bath. Where do I go from here?
Post by stoneyboy » Thu Feb 05, 2009 10:08 pm
Gateman,
Sounds like you still have air in the system, you do need to remove this.
Probably worth adding one of the flushing chemicals to give the system a clean.
Gateman
Post by Gateman » Sat Feb 07, 2009 9:58 am
[quote="stoneyboy"]Gateman,
end[/quote]
[quote]So you're advising to empty system, flush then re-fill?[/quote]
