air lock in pump
roganbloom
air lock in pump
by roganbloom » Sun Feb 10, 2008 11:11 am
I used to have an occasional problem with air in the system which sometimes caused the pump not to start running when turned on. bleeding air from the pump solved the problem but now this is happening regularly although there does not appear to be air inthe system i.e. cannot hear air in system and when rads are vented no air is expelled, all rads hot. Any suggestions
by htg engineer » Sat Feb 16, 2008 9:43 am
If all radiators are getting hot - then the pump isn't airlocked.
Vent all radiators and vent pump, try turning pump down to setting II if on III and see if it makes any difference.
roganbloom
airlock in pump
by roganbloom » Mon Feb 18, 2008 11:59 am
Thanks for the info.I have turned the boiler setting lower i.e. water not so hot and it seems to be working so far.
