Hello.
This is my first post so any help will be much appreciated.
Following the draining down of my system recently the plumber experienced massive problems removing air with boiler locking out on numerous occasions, Potterton Suprima 40.
On discussion with a colleague the plumber informed that a vent pipe was fitted to the top port of the existing air seperator. Additional pipe work was also altered. Previously the cold feed entered the top port of the air seperator, this now enters at bottom port next to feed from boiler. The pump is fed from side port.
This allowed the air to escape system and boiler now works fine. However, several weeks later I discovered that water was pumping over into the f&e tank via the vent pipe although the water level in tank was remaining constant. Obviously this should not be happening and I assume that it has been piped incorrectly. Can anyone please help in any way?
For information. The vent pipe is 15mm and the existing pipe work 22mm would this possibly contribute?
