All radiators not working except for one
Postby Mark J » Mon Oct 26, 2009 8:02 am
Hi, need some help if you can
At my mum's all her radiators are not working except for one, the bathroom one.
I've searched the net and i cant find a matching example of this, if one goes it says to check the TVR, not sure what this is or where it is.
Does this go for me in this situation?
Any ideas?
Cheers Mark
Mark J
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby sparx » Tue Oct 27, 2009 8:08 pm
It is likely the bathroom rad?towel rail is on the hot water circuit which used to be common thing to do.
You have a problem with the heating system, which could be many things from programme / time switch, control motorised valve, pump etc.
I am sure if you give a clue to the system in place someone will help,
IE type of boiler, how many motorised valves and thermostats, hot water tank , pump etc.
give us a clue, & we will return the favour...
regards
Rank: Project Manager
Postby Mark J » Wed Oct 28, 2009 7:45 am
Cheers Sparx
Will try and find out the info and put it on here, she does have a towel radiator though!
Thanks Again
Mark J
Rank: Labourer
25%
Postby casper77 » Tue Nov 17, 2009 7:11 pm
Hi Mark,
I stumbled upon this page because I am facing the same problem - the bathroom towel rail heater is the only one working.
Hot water works fine but the rest of central heating isn't.
anywhere.
When the thermostat is adjusted, the boiler does not respond either.
I got an engineer coming in tomorrow and may be able to tell you about what went wrong with my central heating system
casper77
Rank: Labourer
25%
Postby casper77 » Wed Nov 18, 2009 10:29 am
Turned out to be a stuck valve which always stick to the hot water side only..
casper77
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
