alpha cb24 faulty.
nickjam
alpha cb24 faulty.
by nickjam » Mon Apr 26, 2010 12:38 pm
Hello,pressure gauge fault & water coming out of over flow pipe,on alpha cb24,any help would be welcome many thanks.
by htg engineer » Mon Apr 26, 2010 7:58 pm
Why do you say pressure gauge fault - it's probably doing as it should.
Water from pressure relief ? when heating is on ? or all the time ?
Check combi fill is turned off
htg
nickjam
alpha cb24
by nickjam » Tue Apr 27, 2010 9:42 am
Hi,thanks for reply,have bled from rad still at 3bar with heating/h.w on or off still dripping from over-flow any idea`s,many thanks.
by htg engineer » Tue Apr 27, 2010 7:14 pm
Combi fill must be on or plate heat-ex pin-holed.
htg
