Baxi Solo 50 Ignition problem
Postby zambo » Tue Dec 23, 2008 9:06 pm
I have a spark and pilot is lit, but main burner does not ignite. If I partially cover the flu on the outside wall for 1-2 seconds, the boiler fires up. I realise that this is not a recommended action, but it is the only way I can get the boiler to light.
This problem has now foxed 7 CORGIs. The boiler has been regularly serviced, the last time just a few days ago. The pipes have been vacuumed and the pilot cleaned, and it always works OK for a short while after the service. (It was fine for 10 months before this service in fact) I have had every part on this boiler replaced, but the problem still exists. looking at it from a laymens angle it seems that there is either not enough gas coming through, or too much air, but why would it work OK for a period of time?
I'm not keen on going for a new boiler in case it's a supply problem that would occur anyway. One CORGi suggsted it could be debris coming from my caste iron gas pipe, but there is a filter I believe.
Anyone got any ideas? Cheers in advance
zambo
Rank: Apprentice
Progress to next rank:
21.1%
Sponsor
Simply Build It
Postby Steve the gas » Wed Dec 24, 2008 4:51 am
Does the fan run freely - without struggling?
Steve the gas
Rank: Site Agent
56%
Postby zambo » Wed Dec 24, 2008 12:29 pm
[quote="Steve the gas"]Hi,
Does the fan run freely - without struggling?[/quote]
Hi Steve, yes the fan is running fine. Boiler came on this morning, but it's just as likely to just keep on sparking tonight without igniting. Sometimes I can see the pilot flame through the view window and a spark, and other times just a spark. This is what makes me think that the pilot still has some dirt in it. Having said that the pilot assembly was replaced a while ago, and it still hapened almost straight away afterwards.
A couple of years ago a CORGI cleaned it with a pin (Baxi tell you not to) and it worked for ages after that without any problems.
zambo
Rank: Apprentice
21.1%
Postby zambo » Thu Jan 01, 2009 12:20 pm
OK, folks, anyone know anything about the airflow differential switch. I assume that this comes on when the boiler does. Someone said that there could be a blockage in one of the pipes here. Anyone know where this area is located on the boiler.
zambo
Rank: Apprentice
21.1%
Postby Steve the gas » Thu Jan 01, 2009 3:32 pm
They are referring to the APS, and should not be messed with by none Corgi persons.The tubes or fan spigots could be blocked a little, but, I'm afraid still an RGI job.
Steve the gas
Rank: Site Agent
56%
Postby zambo » Sat Jan 03, 2009 11:15 am
[quote="Steve the gas"]They are referring to the APS, and should not be messed with by none Corgi persons.The tubes or fan spigots could be blocked a little, but, I'm afraid still an RGI job.[/quote]
Cheers Steve, I managed to get through to Baxi yesterday. They say it needs an engineer with a multimeter. They also agree that the fault seems to be linked to the APS and or venturi. I'm just a little nervous about CORGIs at the minute as I have has several look at this problem, and some have fitted parts I obviously haven't needed, like a gas valve, pilot assembly and HT lead. One even changed the pcb, and only put the old one back when I complained it made no difference.
zambo
Rank: Apprentice
21.1%
Postby Steve the gas » Sun Jan 04, 2009 8:06 am
What area of the country are you in ?
Steve the gas
Rank: Site Agent
56%
Postby zambo » Wed Jan 07, 2009 5:51 pm
[quote="Steve the gas"]What area of the country are you in ?[/quote]
Not far from Portsmouth.
zambo
Rank: Apprentice
21.1%
Postby zambo » Fri Jan 09, 2009 4:01 pm
[quote="zambo"][quote="Steve the gas"]They are referring to the APS, and should not be messed with by none Corgi persons.The tubes or fan spigots could be blocked a little, but, I'm afraid still an RGI job.[/quote]
Cheers Steve, I managed to get through to Baxi yesterday. They say it needs an engineer with a multimeter. They also agree that the fault seems to be linked to the APS and or venturi. I'm just a little nervous about CORGIs at the minute as I have has several look at this problem, and some have fitted parts I obviously haven't needed, like a gas valve, pilot assembly and HT lead. One even changed the pcb, and only put the old one back when I complained it made no difference.[/quote]
Still waiting for the 7th CORGI to have a bash at it. One has been back 6 times and another 4. In fact I'm getting fed up of CORGIs, can anyone recommend a good Alsation, I'm sure they would do a better job.
I'm having second thoughts about it being an air problem, because when the boiler is hot and goes off for a bit, the boiler on light flickers and when the temp drops, the boiler comes back on no problem. Also, when it was cold and trying to come on the other day, I tapped the side of it, and the pilot light seemed to get a bit bigger, and the boiler fired.
Still confused.
zambo
Rank: Apprentice
21.1%
Postby Steve the gas » Sat Jan 10, 2009 8:09 am
Has it been serviced? Sounds like pilot partially blocked prhaps, part changing only works by luck-- not good.
Look up Hinton Heating on the web, I know him and he knows what he's doing, he may take it on?
Hth
Steve the gas
Rank: Site Agent
56%
Postby zambo » Sat Jan 10, 2009 3:42 pm
Hth[/quote]
I'm very grateful Steve. Many thanks
zambo
Rank: Apprentice
21.1%
Postby mlcinfl » Fri Feb 27, 2009 11:49 pm
I've only just found your posting so you may already have things sorted.
It sounds to me like you may have a faulty spark electrode. There is probably a hairline crack in the ceramic shield and the control panel is not recognising that the pilot flame has been established.
This is often the fault when a Solo will operate properly from cold but begins to misbehave upon re-ignition after the stat shuts down.
Baxi solo's have always suffered from this problem. I would replace the spark electrode and HT lead.
Good luck.
mlcinfl
Rank: Labourer
75%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
