Biasi 28S boiler leaking from diverter valve
Postby troga123 » Sat Jun 19, 2010 5:36 pm
Hi I have a Biasi 28S boiler leaking from diverter valve, removed and cleaned it but still leaking anyone any suggestions?
troga123
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby htg engineer » Sat Jun 19, 2010 8:12 pm
Buy a diaphragm/service kit, change all seals, o rings a diaphragms.
Can cost anything from £5 - £50 - but alot cheaper than a diverter valve.
htg
Rank: Project Manager
Postby troga123 » Sun Jun 20, 2010 5:33 am
Hi many thanks for getting back to me. A bit odd this, as I said I removed and cleaned everything on Friday, was leaking really badly up till yesterday evening, just after I posted the message, and now seems to be only leaking a few drops per hour. I don't want to strip it down again in case I make it worse.
Do you know of any sort of spray sealer I can use?
Many thanks again.
troga123
Rank: Labourer
50%
Postby troga123 » Sun Jun 20, 2010 7:43 am
Hi just realised I think I've told you the wrong place where it is leaking from, its not from the diverter valve itself, it is where the diverter valve joins the body of the unit.
There are 2 screws that hold it in place, and on the top you have input and output tubes.
Many thanks again[/img]
troga123
Rank: Labourer
50%
Postby htg engineer » Sun Jun 20, 2010 3:03 pm
I know it's a DIY site, but spraying with some sort of sealer is a bodge job and will only be a temporary fix.
htg
Postby eggers » Mon Jul 05, 2010 9:10 pm
is it leaking through the spindle between the water differential valve and the diverter body?
you can try a service kit but chances are the valve will need replacing
eggers
Rank: Ganger
31.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
