Bleeding radiator too often ?
Postby mariew99 » Sat Nov 29, 2008 5:31 pm
One of the radiator needs to be purge off air almost every two weeks as there are loud 'water-dripping' noises within the radiator when the heating is on. Does this mean there is a leak somewhere ?
It is the first radiator to heat-up in the system, with no thermostat on it (don't know if that matters)
It is a brand new combi boiler and an old closed-heating-system so would you expect to have to purge air that often or shall I worry?
Help please?
Thanks,
Marie
mariew99
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby Steve the gas » Sun Nov 30, 2008 5:15 am
Hi Marie,
Its finding air from somewhere.What pressure is the boiler at,which boiler etc - lots more info req.
Steve the gas
Rank: Site Agent
56%
Postby mariew99 » Sun Nov 30, 2008 12:49 pm
It's a Worcester 28i junior and the pressure is around 1bar, lower when off, and never above 1.5 bar.
mariew99
Rank: Labourer
25%
Postby htg engineer » Sun Nov 30, 2008 1:17 pm
There may be a leak on the pipework or manifold, does the system pressure drop ?
htg
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
