Boiler goes off when Hot tap turned on
Postby tdkm » Sun Jan 20, 2008 12:44 pm
A Biasi combi boiler central heating works fine but no DHW as soon as hot tap is turned on boiler goes out
tdkm
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby waynetheplumber » Sun Jan 20, 2008 8:48 pm
sounds like a thermistor sort of problem as its obviously sensing the demand for DHW at the flow switch otherwise she wouldnt change over from heating to DHW.
your best bet is to get a heating engineer to take a look.
waynetheplumber
Rank: Labourer
75%
Postby waynetheplumber » Sun Jan 20, 2008 9:01 pm
if the boiler is on central heating mode then you turn the tap on, if the boiler tries to switch over from heating to hw, then its a thermistor problem or if you dont have the central heating on and you try turning your tap on and it doesnt work then it sounds more like your diverter valve diaphragm.
waynetheplumber
Rank: Labourer
75%
Postby tdkm » Mon Jan 21, 2008 8:38 pm
thanks wayne the plumber - will give that a go
tdkm
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
