Boiler is firing to often
Postby nicksdad » Thu Dec 18, 2008 2:48 pm
Our boiler fires up for approx. 5 minutes goes off for 3 and then fires up again, engineer says that the boiler is okay has checked the flow and return and he said the temperature is dropping very quickly. We have one rad at the end of the line that does not heat up completely, it has a warm spot at the bottom, but the top is hot.
Rank: Labourer
Progress to next rank:
Simply Build It
Postby plumbbob » Thu Dec 18, 2008 7:28 pm
That is very probably normal as boilers can cycle quite quickly. If a rad is hot at the bottom and cold at the top means it is full of air so need bleeding.
Poor flow is the opposite - cold bottom hot top.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
