BOILER PROBLEM
Postby pauly1006 » Mon May 04, 2009 9:16 pm
I HAVE JUST HAD A KESTON QUDOS 28H INSTALLED AND THE FAULT E12 KEEPS COMING UP, THIS SO THE INSTRUCTIONS SAYS A FLOW AND RETURN OVER HEAT THE BOILER IS OK SO IS THERE A PROBLEM WITH THE NEW PIPEWORK OR PUMP ETC
pauly1006
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby bd3cc » Tue May 05, 2009 9:25 pm
Keston technical may well help. Number should be on the Literature left with you. Otherwise, call the plumber back
bd3cc
Rank: Foreman
41%
Postby Steve the gas » Wed May 06, 2009 4:30 am
Hi Pauly,
Firstly -caps lock off please - its regarded as shouting.
If the boiler says its overheating on flow and return - its prolly the boiler that is airlocked.
Bleed the pump, is the AAV open- does it have one?
Hth
Steve the gas
Rank: Site Agent
56%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
