Boiling
Postby Anita1 » Fri Nov 28, 2008 11:16 pm
Hello , we have a problem with our central heating , in the fact that sometimes the room thermostat will not switch off.It clicks but the led stays on , so does the boiler. Its about 7 years old , have changed thermostat.
boiler
3 way valve
cylinder and stat
room stat
pump and programmer
oh if we switch off the mains it works fine again.HELP PLEASE.
Anita1
Rank: Apprentice
Progress to next rank:
0%
Sponsor
Simply Build It
Postby plumbbob » Sat Nov 29, 2008 12:07 pm
The first thing to do is to discount a frost stat that may be overriding the room stat. If you don't have one or it is set correctly, then the three port valve may be faulty. The room stat does not control the heating, it just closes the 3PV which in turn switches the pump and boiler off.
plumbbob
Rank: Project Manager
Postby Anita1 » Sun Nov 30, 2008 10:15 am
Thanks , but what we cannot understand is why the neon light on the room stat stays on , even when you hear it click off.
How would a live feed from the 3pv get back , since the live should come from the programmer if you see what I mean. , No frost stat.
We are convinced it must be the 3pv but cannot see how.
It's a Tower model , can we just change the motor and mechanism ?
Anita1
Rank: Apprentice
0%
Postby plumbbob » Sun Nov 30, 2008 12:48 pm
The 3PV contains various electrical components so if it has failed, anything may be happening. IF we assume the wiring is not at fault, then the problem must be with either the stat or valve. You could download the wiring diagram of the Sundial plan from the Honeywell website, and try to figure out what is happening, but I have done this in a thread before, and the topic ran to many posts from various contributors which caused my head to really hurt, and in the end, we never worked out why other than the change fixed his fault.
When the heating is stuck on, unscrew the stat and remove it from the wall. If the heating remains on, then only one possibility remains.
I think the Tower valve head can be replaced with one from Honeywell as Tower is a cheaper clone of Honeywell. Thing is it may be cheaper to purchase a complete new Tower valve than it is to just buy a Honeywell head. With a complete valve, just fit the part you need and keep the body as a spare.
plumbbob
Postby Anita1 » Mon Dec 01, 2008 2:55 pm
Thanks, just got a new 3pv Tower off ebay for 32 quid, will change the top half first to see if it cures it.
See , us gals are not all useless..............
Anita1
Rank: Apprentice
0%
Postby Anita1 » Fri Dec 05, 2008 11:46 pm
Hmmmmmm. looks like the new top is slightly different from the old one .
Anita1
Rank: Apprentice
0%
Postby Anita1 » Sun Dec 14, 2008 6:17 pm
maybe we are ......
Anita1
Rank: Apprentice
0%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
