Bottle Air Vent leak
Postby agcar1 » Wed May 28, 2008 7:46 am
Have noticed the the Bottle Air Vent on the Primary Return pipe from my Heatrae Sadia Megaflo (indrect unvented system) to the boiler is leaking water, as the washer on the plastic cap has perished.
I've replaced the washer, and that's stopped the leak, but I'm no expert (I didn't even know these vents existed till I was forced to investigate/understand the leak!!), so I don't know how air gets vented from these gadgets.
Do they vent air automatically (i.e. may I now have also stopped the air venting from it, by putting the "wrong" kind of washer on it), or do they simply vent manually (i.e. I suppose I should be loosening off the plastic cap occasionally, in which case I guess the change-of-washer is fine)?
Thanks.
agcar1
Rank: Apprentice
Progress to next rank:
5.3%
Sponsor
Simply Build It
Postby htg engineer » Wed May 28, 2008 3:34 pm
Auto airvents - automatically vent air. As the name suggests.
Closing the dust cap will stop the leak, but will prevent air from escaping - replace auto airvent.
htg
Rank: Project Manager
Postby agcar1 » Thu May 29, 2008 8:47 am
Thanks htg, I appreciate it.
Didn't realise the cap was just a dust-cap and nothing more. As you say, sealing this clearly ain't good! Will replace auto air-vent.
Cheers.
agcar1
Rank: Apprentice
5.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
