central heating bleeding system after replacing rad valve
Postby chrisjsteve » Wed Jan 02, 2008 5:13 pm
i have a laeking valve on my central heating system on a ground floor radiator and need to replace this as i will have to drain to full system when refilling will i need to bleed my boiler it is a ideal standard classic rs40 . my hot water is indirectly heated through my central heating system and my heating system has vented expansion pipe to the heating header tank . as i am a novice please help me thanks any help greatfull recieved thanks
chrisjsteve
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby humperdink » Thu Jan 03, 2008 9:34 pm
if it is just your radiator leaking you can turn off the valves at either side of it to isolate and remove
humperdink
Rank: Tradesman
15.4%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
