Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    Central Heating Boiler
    Post a reply
    4 posts • Page 1 of 1
    Postby CDunn » Fri Nov 23, 2007 11:55 am
    I have a Potterton 28i boiler giving trouble. It keeps heating the hot water by turning the pump for the central heating off and it won't re-start. I have discovered by turning the hot water control to off, the central heating fires up again and works fine. Is this a sensor problem?
    Colin.
    CDunn
    Top
    Postby DONFRAMAC » Sat Nov 24, 2007 12:51 am
    My newly installed Potterton Promax 28 HE+ condensing combi has hot water priority as is standard with combi's. My "duty selector dial" has positions for "reset", "rads. & DHW", "O" for off, and "DHW". The rads. and DHW are sketches. Try your hot taps when apparently deselected ;--- you may find that the unit is actually in DHW priority mode, and suitable for continuous use, alternating flow from taps to rads.
    Detailed info. on control set-up for your particular will be available from BAXI POTTERTON. Aftersales service 08706 017 017, Technical Enquiries 08706 049 049.
    DONFRAMAC
    Top
    Postby htg engineer » Sat Nov 24, 2007 9:57 am
    not sure what you mean by turning the heating pump off to heat the hot water ?
    When heating or hot water is selected the pump will run.
    When you run the hot tap does the green demand light (tap) come on, and go off when the tap is closed ? when the heating is on does the green radiator demand light come on ?
    If you run the hot tap when the heating is on the green light should go to the tap then back to the radiator when the tap is turned off. If it's not then it could be a problem with the diverter valve.
    How old is the boiler ?
    Top
    Postby CDunn » Sun Nov 25, 2007 11:51 am
    The boiler is 6 years old. When the heating is running the radiator light switches off and the tap light comes on without turning a tap on. The radiator light will not come back on until the water control is turned to off. ie to get hot water, I have to turn water control on then off when finished, otherwise we get no radiator heating as it stays constantly on the hot water.
    CDunn
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • oil central heating boiler
      by Mr.Punch » Tue Oct 02, 2007 1:32 pm
      Last post by The Heating Doctor View the latest post
      Wed Oct 10, 2007 11:02 pm
    • CENTRAL HEATING BOILER
      by Ann D » Sun Jan 06, 2008 8:16 pm
      Last post by htg engineer View the latest post
      Tue Jan 08, 2008 9:45 pm
    • central heating boiler
      by mister r » Mon Feb 04, 2008 7:37 pm
      Last post by ericmark View the latest post
      Fri Feb 08, 2008 12:21 am
    • Central heating boiler
      by Ossie » Tue Dec 30, 2008 8:55 pm
      Wed Dec 31, 2008 11:10 am
    • Where to put a central heating boiler
      by jennys » Sun Feb 22, 2009 10:18 am
      Last post by Steve the gas View the latest post
      Mon Feb 23, 2009 5:45 am
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    cron
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
