central heating funny sound
ptg1174
by ptg1174 » Sun Oct 05, 2008 10:20 am
hi guys my central heating works fine but i have just noticed that when the thermastat turns it off there is a sound coming from the radiators sounds like there is small pebbles regurgitatin inside
pls help
Steve the gas
by Steve the gas » Sun Oct 05, 2008 5:35 pm
Could be air, have tried bleeding the rads?
ptg1174
by ptg1174 » Tue Oct 07, 2008 12:06 pm
how much should i bleed them i have done but nothing comes out appart from water and the noise only happens when the radiators are cooling
by htg engineer » Thu Oct 09, 2008 3:15 pm
Can sometimes just be the valve vibrating, I wouldn't expect it to only vibrate when the boiler is off though.
Check the valves, if slightly closed try to remember where they're set to as the system has probably been balanced - try opening the radiator valves fully and see if the noise stops.
htg
screech
by screech » Sun Oct 12, 2008 12:08 am
from your description i'd say it's in the rads themselves. try adding a cleanser. the only solution is flushing the system out or new rads.
