Central Heating Issues - Do I need To Drain and Flush?
Postby trevbp » Fri Nov 26, 2010 11:26 am
I am having major issues with my central heating at the moment.
When the heating comes on, the noise of the pump action is horrendous and continues for as long as the heating is on. There is an additional underlying noise which I can only say at times sounds either a 'low drone' or a car revving its engine and I can also hear 'water gurgling' at times as well. Two radiators do not warm up. One of the radiators that does not heat up I am unable to bleed this radiator as the bleed key does not 'grab' the bleed valve sufficiently. It is generally pot luck as to if all the other radiators heat up.
Also, when we have the hot water on at the same time, the radiators take and absolute age to heat up and more often than fail to heat up.
Any advice / help appreciated...at my wits end
regards
Trev
trevbp
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby DEEARR2 » Fri Nov 26, 2010 9:28 pm
Noisy pump and poor circulation would indicate the pump should be replaced.
DEEARR2
Rank: Ganger
73.3%
Postby King of Powerflushing » Sat Nov 27, 2010 10:23 pm
It could well be the pump.
However, it sounds like you may have some air in and/or around the pump.
If the pump is in you airing cupboard have a look for an air valve there. Turn the pump off and bleed any air out.
If you find an air valve in the cupboard and no air (or water) comes out you may have a blocked feed pipe.
Hope this helps
Ian
Rank: Labourer
0%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
