when I put my central heating on only water heater works. The central heating although it comes on but no hot water circulation. :? :?
3256
Post by htg engineer »
Wed Jan 23, 2008 5:42 pm
Boiler make and model ?
Pump running ?
i gurung
3
Post by i gurung »
Wed Jan 23, 2008 6:00 pm
Boiler is Classis SE 18 FF. Pump is not running
i gurung
3
Post by i gurung »
Thu Jan 24, 2008 5:35 pm
Could anyone tell me whats the problem with my central heating when switched on only water heater works not the central heating, although it is on. My Boiler is Classis SE 18 FF. Pump is not running. :?
frogger
26
Post by frogger »
Thu Jan 24, 2008 6:15 pm
Could be the pump if hot water is gravity.
Could be motirised valve, see if spring on valve is energised, it will be loose if it is.
3256
Thu Jan 24, 2008 7:17 pm
Room stat turned up ?
Pump not running ? maybe the pump is the problem ?
