central heating only works when hot water on
Postby miranda » Fri Oct 26, 2007 8:27 am
Hi guys, Since the cold weather has start to come, I have turned my heating on and the radiators only get hot when the hot water is warming up. Once the water reaches temperature the radiators go cold.
I have bled the radiators and nothing changes. The problem is I dont use enough hot water to keep the radiators on.
Help
Miranda
miranda
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby marrtin » Fri Oct 26, 2007 7:46 pm
Does the pump continue to run after the hot water goes off? Could be a faulty zone valve. Try operating it manually.
marrtin
Rank: Foreman
58%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
