central heating overheating
Deansharman
by Deansharman » Fri Jun 22, 2007 2:29 pm
My boilers overheating and switching off, a plumber in my local B&Q said it probably needs venting as there is likely a air block. where will i find the release valves? i know what it should look like but cant find it. i'm looking for the one off the hot water tank, this i belive is the source of my problem.
wishiwascorgi
by wishiwascorgi » Sun Jun 24, 2007 12:11 am
there should be two 22millimetre pipes entering the cylinder about a 3rd of the way up and the other just above. If you follow them pipes to the highest point there should be a bleed valve situated at the top of the pipe.
toneyt
by toneyt » Tue Jun 26, 2007 9:59 pm
is the pump ok?
