Central Heating Problems
Emma123
by Emma123 » Wed Nov 14, 2007 7:36 pm
I have 13 radiators in my house, I have drained the system and refilled it again. I bled Them all 7 are working 6 arn't. The water returning to the expansion tank is piping hot. Any Ideas what the problem may be?
Thanks in advance
andf380
by andf380 » Thu Nov 15, 2007 5:09 pm
the 6 radiators that are not working have you tried bleeding them and only cold water is coming through you could try turning the 7 radiators that are working off at the valves which will push more pressure onto the 6 that are not working.
andf380
by htg engineer » Thu Nov 15, 2007 6:18 pm
Sounds like an airlock, but first check all radiator valves are open, did you cloase any ?
The easiest and quickest way to try and clear a airlock is to turn off the radiators that are working. Hopefully the pump will push the water through to the other radiators.
Can you provide the make and model of boiler, so that I can try to help more.
Emma123
by Emma123 » Sat Nov 17, 2007 3:04 pm
[quote="htg engineer"]Sounds like an airlock, but first check all radiator valves are open, did you cloase any ?
Can you provide the make and model of boiler, so that I can try to help more.[/quote]
The Make is warmflow and the model is 70/90
roger196
by roger196 » Sat Nov 17, 2007 5:40 pm
Was the system working before you drained it
When you drained the system, did you close the valves at boths end of the radiator or just the thermostatic valve end..
Are the non working radiators all upstairs.
