Post
by htg engineer »
Fri Nov 09, 2007 3:52 pm
The pump will have a switch on the head marked I, II & III, these are the speed settings try turning up to III.
Also try venting the pump - turn the big silver screw anti-clockwise. There should be water there. If it's steam that comes out, then the pump is faulty and overheating.
Pretty easy to change the pump, as long as the pump valves don't leak (probably will) as you look at the pump there's 4 bolts securing the head to the body undo these and put the new head on the same way. Ensure the rubber seal is in place.
