Tweet
Trustmark and the NHIC
Central Heating Pump
Having replaced some radiators I found it necessary to bleed the pump. When I did this some water emerged and the note of the pump changed resulting in a fully working system. However i seem to have to go through this procedure whenever the system is off for a while. What is causing this?
Sponsor
it could just be air that's circulating around the system, it may take a few attempts at venting the pump to get rid of it. Did you say you've changed the pump ? is it fitted according to instructions ?
[quote="htg engineer"]it could just be air that's circulating around the system, it may take a few attempts at venting the pump to get rid of it. Did you say you've changed the pump ? is it fitted according to instructions ?[/quote]
Many thanks. It does seem to be improving.
3 posts • Page 1 of 1 Return to Central Heating & Air conditioning & Ventilation
Powered by phpBB ® Forum Software © phpBB Group
Diy Doctor Ltd (Company No. 5863375)
DIY | DIY How To | DIY Forum | Terms & Conditions | Privacy Policy | Cookie Info
