Price Doctor - Extension quote and price checking software
The Southern Homebuilding and Renovating Show 2013, Sandown Park, Surrey
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Central Heating & Air conditioning & Ventilation
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    Central Heating Pump
    Post a reply
    3 posts • Page 1 of 1
    Postby Madmas » Thu Feb 14, 2008 5:45 pm
    How do I test if pump is actually pushing water around system ?.
    Boiler engineer said water boiler OK but no water is being returned to it, so boiler keeps shutting down. No hot water or heating.
    I have been told that even though i can hear and feel pump working, it may still NOT be pumping water.
    Madmas
    Top
    Postby htg engineer » Thu Feb 14, 2008 9:04 pm
    Sometimes the impeller breaks or comes away from the motor, the easiest way to check is to turn off both valves and remove the pump head - check the impeller and replace pump head if necessary.
    If you go to the hassle of doing this - would it not be better to replace the pump head anyway, it may solve all your problems.
    Top
    Postby Kenj » Sat Feb 16, 2008 3:40 pm
    Easiest way to test that pump is functioning is to feel the pipes feeding into it and away from it.
    When you turn system on from cold, hot water from the boiler should rapidly heat up the flow pipe to the pump. The heat should then pass through the pump, motorised valve, and to H/W cylinder and/or heating pipes.
    If the pump is not working the boiler will soon shut down, although the pump may continue running to dissipate the excessive heat from the boiler ( fanned models). An air lock in the pump can cause these symptoms.
    Heat will radiate along the pipes from the boiler with the pump not working, but the flow will be very slow, and the boiler will continually overheat and cut out.
    Kenj
    Top
    Post a reply
    Return to Central Heating & Air conditioning & Ventilation
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • No central heating - twin pump heating system
      by morrismob » Tue Oct 02, 2007 8:12 pm
      Last post by The Heating Doctor View the latest post
      Fri Oct 12, 2007 12:07 am
    • Central heating pump
      by ALFER » Thu Apr 05, 2007 1:11 am
      Last post by ALFER View the latest post
      Fri Apr 06, 2007 9:23 am
    • Central Heating Pump
      by rob rolfe » Mon Nov 12, 2007 11:28 am
      Last post by rob rolfe View the latest post
      Tue Nov 13, 2007 10:27 am
      by VcRwL » Tue Dec 11, 2007 8:45 am
      Last post by Perry525 View the latest post
      Wed Dec 12, 2007 6:04 pm
    • central heating pump
      by abrad38 » Sat Aug 16, 2008 2:24 pm
      Last post by Steve the gas View the latest post
      Sat Sep 20, 2008 5:13 am
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
