central heating radiators
Postby brendan staunton » Tue Nov 18, 2008 9:43 pm
I ´ve just had central heating fitted @ some of the radiators have the inlet valve fitted on the outlet side & vice versa, & as at later date we may want to fit thermostatic valves, will they work efficiently? Also the last radiator in the line is not getting hot, it´s been bled so it´s not an airlock, the fitter says the reversal is not a problem, what do you think?
Brendan[quote][/quote]
brendan staunton
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby Steve the gas » Wed Nov 19, 2008 6:37 am
Hi Brendan,
Firstly, TRVs should have been fitted yo all rads apart from one - it is a reg now.
Yes put them on any side as long as you buy the type that are bi-directional.
Hth
Steve the gas
Rank: Site Agent
56%
Postby kirstyf » Wed Nov 19, 2008 4:49 pm
Hi guys, Looking for some help related slightly to your topic so hope someone can help!
I have central heating in our flat.
I recently bled all the heaters as the place seemed cold. The one in my bedroom remained cold.
I checked the bleed valve at the bottom which is turned right round. The heater makes quite a bit of noise & still remains mostly cold. One area at the bottom gets hot but the rest of the heater is cold..so it's really not heating up the room.
Every other heater is fine but this one.. :(
any suggestions? Help much appreciated!
k
kirstyf
Rank: Labourer
0%
Postby nitro23456 » Wed Nov 19, 2008 4:52 pm
TRVs are a regulation, they should have been fitted.
nitro23456
Rank: Foreman
48.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
