Cold House - Boiler issues?
Postby clairy » Wed Nov 26, 2008 9:39 am
I have a Worcester Combi Boiler, fitted c 8 years ago. I constantly have to manually re-pressurise it and 3 years ago paid over £600 to have it descaled and serviced as well as trying to find the problem with the depressurising (perhaps I would have been more economical fitting a new boiler!). Anyway, I live in a ground floor 3 bed flat with garages underneath which does not help, but I would like to know before I go and spend more money on an engineer if there is anything I can do to help the performance of the boiler. I am having to turn my thermostat up constantly and whilst the rads are hot, the rooms do not feel that warm. (I do have double glazing).
How long should a boiler last? Are there any known problems with the Worcester boilers (I understood they were one of the better ones) How do I find out it I have enough rads / or if they are placed in the correct areas of the room? I would need someone to do all the work for me, but I don't want to appear ignorant if I do get people in to quote for me!
Thanks!
clairy
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby warren jeffery » Wed Nov 26, 2008 7:21 pm
[quote="clairy"]Hi
if the rads are hot its not the boilers fault they should reach around 80 if they do. then they are to small for the rooms or are of the old non convecting type or you have poor insulation values
Thanks![/quote]
warren jeffery
Rank: Apprentice
0%
Postby Steve the gas » Thu Nov 27, 2008 5:39 am
Hi Clairy,
WB are allegedly one of the better makers.You either have a leak somewhere or the PRV is dumping water,we need you to check for both then post back.
Steve the gas
Rank: Site Agent
56%
Postby clairy » Thu Nov 27, 2008 11:14 am
Hi Steve
I'll get onto that - not being technical (or blonde!) what is a PRV?
Claire
clairy
Rank: Labourer
25%
Postby Steve the gas » Thu Nov 27, 2008 6:16 pm
Hi Claire,
Pressure Relief Valve - the pipe that goes outside from (normally) just under the boiler. Put a plastic bag/balloon on it to see, unless you spot it.
Hth
Steve the gas
Rank: Site Agent
56%
Postby afmckee » Thu Dec 18, 2008 5:17 pm
Hi - I have a different brand boiler but have had the same issues as the previous poster. It is so frustrating to feel ignorant and that we possibly have a lemon boiler (Weil-McClain). It's only 9 years old and in the past 3 years we have spend over $2000 on various repairs!
Anyway, the tank off to the side of the boiler drains water into a tub we put under the pipe coming out of it. However, this is usually after we've had to adjust the psi up. We have seen no leaks anywhere around any radiators.
Further, several parts have rusted out and/or burned out - hence, the costly replacement repairs. They claim it's because our basement has so much moisture. Yet our basement isn't wet, there's no condensation on the walls or windows. A friend suggested there is condensation dripping within the boiler unit itself. . .
A new boiler will be around $6000. This is a lot of money, especially after just putting so much into the existing one. Help! Advice? Thanks!
afmckee
Rank: Labourer
0%
Postby Steve the gas » Fri Dec 19, 2008 5:40 am
I'm not familiar with that make, obviously, but if water is being dumped after pressure going up, then PRV is leaking below normal blow off pressure approx 3 bar + (45psi)
If this is happening change PRV .
Hth
Steve the gas
Rank: Site Agent
56%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
