cold water gets heated up
Postby jobin jose » Sun Feb 10, 2008 5:21 pm
hai
i am having a baxi solo central heating system.its having a cold water tank in the attic.water in the tank gets boiled and falling on to the attic. what should i do
jobin jose
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Sun Feb 10, 2008 8:37 pm
hai
'i am having a baxi solo central heating system.' ???
You have ? or you're having one fitted ?
'its having a cold water tank in the attic.' ???
water in the tank gets boiled and falling on to the attic. what should i do ??
Try posting again, give as much info as possible.
Rank: Project Manager
Postby ericmark » Sun Feb 10, 2008 9:27 pm
First turn down temp on boiler, if this does not work then plummer as you will most likely need replacement parts fitting and these need to be fitted by someone who knows what they are doing.
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
