combi boiler high pressure guage reading
Postby bongo » Wed Sep 03, 2008 6:14 pm
I have a baxi 105e combi boiler that is causing the pressure to rise rapidly to 3.5bar ( ie 24 hours ) whereupon the pressure relief valve operates. I let the pressure out via the relief valve to .7 bar to keep it running which it does fine. It does this if using hot water mode only or both. I've checked the expansion vessel and seems to be ok no water in it,Boiler only 4 yrs old any ideas ?
bongo
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Thu Sep 04, 2008 10:47 am
If the pressure vessel is ok, and the combi fill is disconnected - then it's probably the plate heat-ex causin the problems, the smallest hole in the heat-ex will allow water to enter the heating section.
htg
Rank: Project Manager
Postby bongo » Thu Sep 11, 2008 6:44 pm
Thanks to htg engineer plate exchanger replaced, boiler now sorted.
bongo
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
