Combi Boilers
6 posts   •   Page 1 of 1
Brooker
Combi Boilers
by Brooker » Sat Feb 03, 2007 4:49 pm
Which is the best make of combi doiler ??????????
george
by george » Thu Mar 01, 2007 4:58 pm
I HAVE A COMBI BOILER 4 YEARS OLD. WHEN I SWITCH THE CENTRAL HEATING ON THE RADIATORS GET HOT, BUT THE PRESSURE GUAGE READS 3 BAR PLUS. WHEN I TURN THE HEATING OFF WITHIN MINUTES THE GUAGE READS ZERO.ON INSPECTING THE PIPE FROM THE PRESSURE RELEASE VALVE I HAVE NOTICED A VERY SLIGHT DRIP. ANY IDEAS WOULD BE WELCOME THANK YOU.
thedoctor
Combi boiler
by thedoctor » Thu Mar 01, 2007 8:18 pm
Take a look at the projects section and click through the central heating projects. There is a link in there to the Gas Mans site. He will email you answers to questions on boilers and central heating questions. You can also use the appointments section on the website for another month. DIYDOCTOR
KEVANS02
by KEVANS02 » Wed Mar 14, 2007 8:42 pm
The fault is more than likely to be the exapnsion vessel. it may have lost its charge or the diaphragm inside may have split. worst case will be you need a new vessel , best case it will just need recharging
hope this helps , kev
thedoctor
by thedoctor » Fri Mar 16, 2007 12:50 pm
MANY OF THE ANSWERS TO YOUR POSTS CAN BE FOUND, WITH DIAGRAMS, IN THE DIYDOCTOR PROJECTS SECTION. CLICK HERE www.diydoctor.org.uk/projects.htm
crowballs
pressure valve
by crowballs » Sun Apr 08, 2007 8:37 pm
May be as simple as foreign body caught in valve...with pressure high valve will open slightly...could be the case
