Combi - Heating Comes on When Tap is run?
Postby SteveK » Sun Jun 03, 2007 9:14 am
[b]Boiler:[/b] Alpha Ocean eco240
[b]Problem:[/b]
When a tap/shower is turned on the Central Heating comes on [b][color=red]RED HOT[/color][/b]. Even though all the central heating controls indicate that the CH is not on. When the tap/shower is off the CH goes off.
ie. No light is on (only water), manual switch (inside timer) is set to '0' or 'auto'.
The CH is supposed to turn [b]off[/b] when the any water is run, but i get normal temperature water and red hot heating
Any ideas anyone, i have never had a problem with this boiler since installation in 1996. Please do not diss this boiler as many engineers do not like them.
SteveK
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Tue Jun 05, 2007 11:16 am
heating comes on when hot water tap on ? if so there's a problem with the diverter valve, may be the diaphragm or dirt on the valve seating. Heating flow will heat up a little bit when hot water tap turned off, this is just getting rid of the excess heat left in the boiler.
Rank: Project Manager
Postby SteveK » Tue Jun 05, 2007 7:31 pm
Thanks, Managed to get a heating Engineer (specialist in Alpha). He 'Re-sealed' the valve and everything is back to normal.
[b]Cheers[/b]
:P
SteveK
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
