condensate pipe
Postby bazza » Thu Jul 17, 2008 8:20 pm
hi guys my freinds boiler keeps leakin every few weeks it seems to leak once qite abit then stops 4 a few weeks then it happens again looked inside the boiler and cant find a leak anywhere on the componants and the system pressure stays at 1.3bar so the leak cant be on the system the only thing i was wonderin if if cud be the condensate pipe at fault as it dosent av much of a fall hardley any so is it possible it cud be backing up and spilling over cause i think the leak maybe coming from the plastic tub at the back right hand corner but cant see it 100% so i cud be wrong but is wat im thinking a possability or not and if so will correctin the fall cure the problem cheers bazza ps the boiler is a glowarm 30cdi thanx
bazza
Rank: Ganger
Progress to next rank:
79.3%
Sponsor
Simply Build It
Postby Skids » Fri Jul 18, 2008 8:27 pm
Hi bazza
leak or overflow ?
howlong has it been happening?
sounds like overflow
new boiler? ~ if so get the installer back in!! fix the fall
old boiler? component problem?
Regards
Skids
Skids
Rank: Ganger
52%
Postby htg engineer » Fri Jul 18, 2008 8:29 pm
Yes increasing the fall of the condnesate discharge piepwork should help - if this is where the leak is from. From what you have said this is what it points to.
htg
Rank: Project Manager
Postby bazza » Fri Jul 18, 2008 9:09 pm
thanx htg engineer great help cheers bazza
bazza
Rank: Ganger
79.3%
Postby htg engineer » Sat Jul 19, 2008 4:56 pm
If it was the overflow (pressure relief discharge) the system pressure would fall - this is not happening.
htg
Postby bazza » Sun Jul 20, 2008 4:34 pm
cheers guys appreciate it thanx
bazza
Rank: Ganger
79.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
