continuing heating/hot water prob.
Postby bcam » Thu May 24, 2007 8:28 am
Hi all, me again, i managed to install my new pump without draining the system( just quickly took it off and put in new one) i now have hot radiators, a noisy pump and no hot water !!!
I know hot water isn't being pumped to the loft tank so that means there is a load of air right? so i tried to loosen the highest pipe i could get to its above my water tank with a bolt on end cap, but i cant loosen it without thw whole pipe turning in the next join down, so if i kept turning it would just break and flood, is there any other way i can get air out of the sysem ? i've bled all the rads and the boilerbut still water wont get up to the loft!
thanks in advance.
Bryan
bcam
Rank: Apprentice
Progress to next rank:
10.5%
Sponsor
Simply Build It
Postby htg engineer » Thu May 24, 2007 4:20 pm
is it a back boiler ? with elson tank ? take out thermostat from boiler and put boiler on, you will here when its clear.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
