Post
by plumbbob »
Wed Apr 15, 2009 9:26 pm
Often compression joints used without any sealant will weep when used with oil.
Since the "olden" days, I have used a product called "Red Hermetite" which is a non setting sealant that is resistant to temperature and oils. This product or similar was used everywhere from car engines to oil installations.
I believe it is no longer available, but a similar product called Red Hylotyte can be found in most garages and car accessory shops.
Generally, I would say he has used the correct product, but of course that doesn't mean joints won't leak. Oil is a beast, because it doesn't evaporate, even the smallest weep from a joint will spread and appear worse than it actually is.
If the joint is leaking maybe a quick nip up will solve the problem, or perhaps some more sealant is required.
