Dead Boiler
Postby bcam » Wed May 09, 2007 11:36 am
Hi all, just new to the forum so hello, the problem i have is , my boiler ( not sure what model ) has decided to stop working so i have no heating or hot water, the pilot light is still lit but when i try to turn it on there is nothing!! previously when i turned on the power there would be a click and the burner would kick on but there is absolutely nothing now!
Does this sound familiar to anyone?
Any advice is more than welcome.
Cheers.
Bryan
bcam
Rank: Apprentice
Progress to next rank:
10.5%
Sponsor
Simply Build It
Postby DONFRAMAC » Wed May 09, 2007 10:49 pm
I have read in this Forum, that the pump can be a mite reluctant to move if left unused for a while, but might respond to setting it to max speed (my Grundfos has 3 speeds). Elsewhere in this forum I read about a bleed-point at the pump where a screw-driver might be inserted to persuade a stuck impeller to move. Pumps can get so crudded that even tho' they may sound and feel healthy, they produce practically no flow.
My pump costs only £71 inc VAT. and can be replaced without any draining, as there is an isolating valve fitted onto each end.
DONFRAMAC
Rank: Ganger
96.7%
Postby bcam » Thu May 10, 2007 8:55 am
Fantastic, thanks for the advice, i'll give it a try.
Bryan
bcam
Rank: Apprentice
10.5%
Postby dave p » Thu May 10, 2007 1:48 pm
need a few more details on the boiler
dave p
Rank: Apprentice
94.7%
Postby dave p » Thu May 10, 2007 1:50 pm
dont bother. if the pump was faulty the boiler would fire for a short while then overheat. its more likely to be programmer or motorised valve
dave p
Rank: Apprentice
94.7%
Postby bcam » Fri May 11, 2007 7:15 am
The boiler is a Baxi wm 381 RS, i found the plug fuse had blown so i tried a higher rated fuse , it also blew, i traced the wiring and found no shorting but when i tried the higher fuse the pump tried to move for a nano second then the fuse blew, do you recon its the pump and it may be a case of changing it and everything will be hunky dory??
I couldnt find a PCB anywhere on the boiler amd had it practically stripped.
Bryan
bcam
Rank: Apprentice
10.5%
Postby bcam » Fri May 11, 2007 1:39 pm
Quick update, can now get the boiler to fire but stops after around 20-30 secs, i can only assume from an earlier answer that the pump is indee knackered and needs replacing.
Cheers.
Bryan
bcam
Rank: Apprentice
10.5%
Postby securitya8 » Fri Nov 21, 2008 11:16 am
yes i agree to you and if you can find the problem you can rectify that in many ways to your air conditioning
securitya8
Rank: Labourer
0%
Postby Steve the gas » Sat Nov 22, 2008 6:26 am
What??
Steve the gas
Rank: Site Agent
56%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
