- HOME
- DIY PROJECTS
- DIY TIPS AND TRICKS
- REVIEWS
- GARDENING
- DIY VIDEOS
- GREEN LIVING
- HIPS
- FIND TRADESMEN
- PRICE DOCTOR
- FORUM
- BLOG
- NEWS LETTER SIGNUP
- SHOP
- SUPPLIERS
- ADVERTISE HERE
- PRESS
Recommend This Page
Tweet
Trustmark and the NHIC
Do building control check diy electrics
I am currently doing a house conversion in mid wales and my uncle who was a qualified electrician some years ago, but does not now hold the necessary certificates- has offered to rewire the whole house. I have heard from a third party that this is fine as building control will come and check the installation for a small fee, is this true please reply asap!!!!!![/b]
How do i go about the process of the application, do i just notify building control of my intentions regarding my uncle doing the electrics ?
Local Authorities often have slightly different systems i.e. some inspect the work themselves and others employ third party companies. Your uncle may have to produce a sort of cv detialing his experience so they can assess the level of check. Does he have city in guilds and testing electrical works qulaifiactions. Have a look at the councils website and this should tell you, and also let you have a building notice and the fee.
May be a bit late but the certificate for a new installation has provision for three signatures.
Designer Installer Tester If your uncle is allowed by building control to sign the first two then may be better to get someone else to do testing mainly because the test equipment is so expensive. There is a link in projects to the gov Part P and you can down load the document which gives sample forms etc. Well worth down loading also be aware on July 1st the new 17th Edition wiring regulations come into force which may change the way you would want to wire a house. New cables and/or use of RCD's new volt drop limits etc.
5 posts • Page 1 of 1 Return to Building Regulations & Planning Permission
Powered by phpBB® Forum Software © phpBB Group
Diy Doctor Ltd (Company No. 5863375)
DIY | DIY How To | DIY Forum | Terms & Conditions | Privacy Policy | Cookie Info
