Do Regs apply?
Postby ma701ss » Sat Jan 03, 2009 4:07 pm
I don't understand how you determine if regs apply, and if so, which ones? If refurbishing an old house to modernise it, how do you know which regs apply? If you do something that requires full plans to be submitted, i.e. build over a sewer, does that mean that everything else you are doing that wouldn't otherwise have been subject to approval, then needs approval? I've read the approved docs, building regs guide, etc. but everything seems so vague.
ma701ss
Rank: Apprentice
Progress to next rank:
0%
Sponsor
DIY asbestos test kits
Postby thedoctor » Sat Jan 03, 2009 10:10 pm
Contact the building control dept of your local council. They will be happy to tell you which regas apply to which job.
thedoctor
Postby ma701ss » Sat Jan 03, 2009 10:18 pm
Thanks, I probably will, but I would like to understand for myself how to determine what needs to be done.
ma701ss
Rank: Apprentice
0%
Postby thedoctor » Sat Jan 03, 2009 10:29 pm
If you have read the regulations documents (all avaialable from our building regulations project) and are not able to work it out from there you will not be able to work it out. In really general terms you will need regs approval for anything which can alter the structural stablity or integrity of the property or the properties services. This also includes the strength of the materials used and the methods of reconstruction. Even time served builders cannot always work out what needs regs approval and what does not so if your construction over a drain requires a lintel to be inserted, then some masonry or a floor is to be laid on or aver the lintel, the floor may need approval also. There is never really a "bog standard" renovation so the rules need to be applied in many different ways in all circumstances
thedoctor
Postby eljaybee » Sun Jan 04, 2009 9:09 am
The planningportal website does have quite a good interactive house which explains what works require permission. It even includes the fact that if replacing more than 25% of a layer of a thermal element (eg replastering, re-rendering, recovering a roof) then you need to increase the insulation and thermal efficiency of the whole element to current standards.
eljaybee
Rank: Ganger
18.7%
Postby ma701ss » Sun Jan 04, 2009 5:44 pm
Thanks I'll take a look.
ma701ss
Rank: Apprentice
0%
Postby ma701ss » Sun Jan 04, 2009 7:32 pm
[quote="eljaybee"]The planningportal website does have quite a good interactive house which explains what works require permission. It even includes the fact that if replacing more than 25% of a layer of a thermal element (eg replastering, re-rendering, recovering a roof) then you need to increase the insulation and thermal efficiency of the whole element to current standards.[/quote]
eljaybee, sorry I had a good look on that site but can't find what you're referring to. Could you post a link please?
ma701ss
Rank: Apprentice
0%
Postby eljaybee » Mon Jan 05, 2009 7:22 pm
If you Google "planningportal.gov.uk" and search for uploads > hhg > and then view houseguide
eljaybee
Rank: Ganger
18.7%
Postby the specialist » Fri Jan 09, 2009 8:11 pm
My understanding after discussions with building control officers is as follows:
Anything structural.
Anything which involves renewing 25% or more of an existing building.
All extensions except a true conservatory.
Converting any space into habitable (basement,loft, garage etc)
Aslo if you are not fensa registered you can still replace windows under a building notice (fee £70.00)
Daft thing is we built a porch with a floor area of14M2 which had a dual pitched roof, vaulted ceiling and velux. The client had to have planning permission yet no building regs. We were converting the basement at the same time but building Inspector didn't even look at it!
the specialist
Rank: Ganger
24.7%
Postby ma701ss » Sat Jan 10, 2009 11:17 am
I posted a useful link to the planning portal interactive house on here after I found it, but the admin seems to have deleted it for some reason. Why?
ma701ss
Rank: Apprentice
0%
Postby Pazuzu » Sun Feb 01, 2009 3:52 am
[quote="ma701ss"]I posted a useful link to the planning portal interactive house on here after I found it, but the admin seems to have deleted it for some reason. Why?[/quote]
I found such a link on the diydoctor home page, useful links - if you scroll down it is at the bottom of the list.
I tried to "pm" you - but that is disabled on this forum, apparently. :oops:
Pazuzu
Rank: Labourer
0%
Postby reggieroo » Fri Feb 27, 2009 3:21 pm
[quote="the specialist"]My understanding after discussions with building control officers is as follows:
[/quote]
What about adding a log cabin as an extension & taking out a window & replacing it with a patio door for access into the cabin?
reggieroo
Rank: Apprentice
36.8%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
