draining combi to add radiator
Postby rambo77 » Mon May 21, 2007 8:42 pm
can anyone advise me on how i go about draining my central heating system to add a new radiator i have a combi boiler i just need to know how to drain and refill it so i can add the rad...
also how do i find out if my boiler will be able to handle an extra rad
regards
rambo77
Rank: Ganger
Progress to next rank:
20%
Sponsor
Simply Build It
Postby htg engineer » Thu May 24, 2007 9:23 am
you can drain a combi from a radiator, either from a drain point or by removing a radiator af fitting a hose to the valve. You need to establish whether the combi is pressurised or tank fed (majority are pressurised) If the system is pressurised just drain the system there's no need to turn off any water supply. To re-pressuirise there'll be a combi fill on or near the boiler, it may be an internal combi fill or two valves under the boiler that will have to be connected with a flexible filling loop. Fill to about 1.5 bar and vent radiators, re-fillin until all rads are full and the pressure is between 1 and 1.5bar (may nee to open Auto air vent and possibly need to vent pump.
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
