economics of gas central heating
Postby jean » Wed Mar 04, 2009 7:31 pm
has anyone done a test to see if it is cheaper to leave heating on 24/7 at a temperature of 18 degrees.
or to put onto a timer system coming on and off twice a day. I can never work it out, can you help.
maany thanks in advance
jean
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby Steve the gas » Thu Mar 05, 2009 4:16 am
Hi Jean,
To be honest - I think there are too many variable factors that contribute to the end result.
Such as insulation values, cavity walls, double glazing, building materials etc.
The only thing I can suggest is - perform your own test and compare, but the weather won't be constant ....will it? 8)
Steve the gas
Rank: Site Agent
56%
Postby acsimpson » Thu Mar 05, 2009 2:51 pm
Of course it also depend on the temperature you are going to heat the house to twice a day.
acsimpson
Rank: Foreman
4.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
