Hoping someone can help with a question on foundation widths. For my new dwelling I had an enginner do some loading calculations to work out the required foundation size. The maximum loading from walls/roof/floors/wind/snow etc was 55KN. The ground was pretty good and I would estimate that it would take a bearing capacity of 100. So working this out 55/100 would give a required foundation width of 550mm. The engineer specified 650mm x 300mm strip foundations with 1 layer A393 mesh bottom (to be on the safe side)
As the cavity wall width was 350mm the builders built a 450mm wide footing on the foundation and then the 350mm cavity wall on top. My question is as follows - will the foundations be OK without a 150mm projection either side? As the footings are 450mm on a 650mm wide foundation this only leaves 100mm either side.
I know there isnt much that can be done at this stage as the house is substantially complete, but would like to set my mind at rest.
- HOME
- DIY PROJECTS
- DIY TIPS AND TRICKS
- REVIEWS
- GARDENING
- DIY VIDEOS
- GREEN LIVING
- HIPS
- FIND TRADESMEN
- PRICE DOCTOR
- FORUM
- BLOG
- NEWS LETTER SIGNUP
- SHOP
- SUPPLIERS
- ADVERTISE HERE
- PRESS
