Glow Worm 30CXi pressure problems
quickshaun
Post by quickshaun » Sat Apr 05, 2008 5:07 pm
Hi my 30cxi has suddenly started losing pressure it takes around 36 hours for the pressure to drop from 1 bar to 0.
I have checked all the accessible joints under my floor and I haven't noticed any water marks in my ceilings.
What I have noticed is that the pressure doesn't seem to rise above 1 bar even after I have had the heating on for some time.
Also there is no water escaping from the 'blow off' pipe outside.
I would be grateful for any advice on the problem.
Thanks in advance.
Post by htg engineer » Sun Apr 06, 2008 9:23 am
If the pressure definately doesn't rise
and there's no leaks from the pressure relief discharge pipe then it points to a leak somewhere in the system.
Is this a condensing boiler ?
The secondary heat-ex sometimes splits and you can lose the pressure via the condensate discharge pipework. Hard to diagnose though - as when the boiler is on there'll be water coming from the exhaust gases.
If the boiler is under warranty - get the manufacturers out
