Heated Towel Rail Problem
Postby njguarnieri » Sun Feb 15, 2009 4:51 pm
Can anyone help?
I've recently moved into a new house. Some of the radiator tops were cold so I went around bleeding them. There was also what appeared to be a bleed point on the top of my heated towel rail, so I did the same. The whole thing is now cold and will no longer heat up, what have I done?!?!
njguarnieri
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby Steve the gas » Mon Feb 16, 2009 5:42 am
Need more info - boiler make/model & system type
Steve the gas
Rank: Site Agent
56%
Postby matthewm1965 » Wed Feb 18, 2009 5:23 pm
Did you bleed it with the heating switched off? If not, then the pump can suck air into the system.
Matt
matthewm1965
Rank: Tradesman
26.9%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
