HI
Could someone please help?
I have a comb boiler installed in my Caravan Mobile Home and the Thermo Valve is leaking I understand that you have to drain down the system to replace this.
My Problem is that the system installed is pressurized and it contains Anti-Freeze for over the winter periods this allows me to drain down all the other water systems in the Caravan without touching the heating system. My concerns are how I go about replaceing the anti-freeze once I have fixed the leaking valve.
Is there some sort of kit I can purchase which allows me to get new Anti-Freeze back into the system and where would you pump this into? I expect it would be through one of the Rads?
