hot water pipes
Postby screbhead » Tue Oct 09, 2007 8:14 am
are pushfit fittings permanent on hot water pipes
screbhead
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby antony5378 » Tue Oct 09, 2007 2:16 pm
Depends which push fit fittings have been fitted, e.g. "speed-fit" fittings can be unscrewed, "poly fit" fittings are permanent.
If there's no way of unscrewing the fitting, it's permanent, unless you break it off with a bit of force.
If the fittings attached to copper, fitting can be replaced for a speed-fit reusable fitting. If it's attached to plastic piping, stick with the same brand of pipe for the fittings.
antony5378
Rank: Labourer
75%
Postby The Heating Doctor » Tue Oct 09, 2007 11:28 pm
I have to correct the previous poster Speed fit & poly fit are demountable these are WHITE in colour. Poly Plumb is a non demountable fitting and is GREY in colour. Push fit copper fittings Tectite Classic from yorkshire fittings is demountable (tool required) but Tectite Sprint is a use once fitting. No doubt there are other systems out there but as antony5378 said it depends on the make.
The Heating Doctor
Rank: Foreman
4.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
