Hot Water Problem with Combi
Postby CraigMorrison » Thu Dec 18, 2008 10:55 am
Hi, I have an Ariston EuroCombi that does not modulate up in hot water mode. I have replaced the diaphram in the diverter valve, the diverter activates the micro switches and the boiler switches on in response to a call for hot water, but the burners remailn low. Could it be a fault with the temp control stat, gas modulator or pcb - any ideas or process of elimination would be appreciated!
CraigMorrison
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby htg engineer » Thu Dec 18, 2008 9:04 pm
First thing to check (been caught out with this once), check the gas meter ECV is fully open - it may have been knocked and may be partially closed.
The burner pressure may need resetting, or may be fault with the gas valve (either way you need a RGI).
htg
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
