hot water system
trevors50uk
hot water system
by trevors50uk » Mon Jul 02, 2007 4:20 pm
I have recently changed a cloakroom toilet and cistern. But now want to change the sink.
I am ok with isolating the cold water but unsure about isolating the hot water to the sink.
The heating and water are supplied from a combi boiler.
toneyt
by toneyt » Mon Jul 02, 2007 6:27 pm
you should be able to isolate the hot water as it enters the combi,then open your hot taps to confirm isolation
by htg engineer » Mon Jul 02, 2007 8:11 pm
With a combi boiler turning off the mains cold water supply, will stop the water to the hot taps as well as the cold taps.
plumbers1
Hot Water
by plumbers1 » Sun Jul 08, 2007 9:32 am
Also make sure you turn down the hot water temp nob or isolate boiler as some can go to lockout if the hot tap is opened to suply hot water with the mains water turned off.
